I installed the s2000 injectors over the weekend and in 30 minutes I had amazing results. I set the regulator at 31 psi with about 4:1 rise. The bike came alive. I also removed the micron can.The exhaust now dumps under the footpeg.I'll take it to the track Sunday.Peak fp is 64 psi @ 8#s. High boost is at 12#s for now. The most I will run is 14#s on this motor.
