Pull the wheel (15mins) take it to the shop and have them change it and balance it....cost you $20......or do you have changer and balancer machines.The time is rapidly approaching when I am going to have to change the rear tire on my Busa. I am considering doing it myself -- with the proper tools of course.
Do many of you change your own or do people take 'em to the local shop?
Stick with the 190Oh, by the way, you guys tried the D280 ZR 190 or the 200? I ask this since the original Busa tyre is larger than a 190 according to some of the posts above...
(i really can't wait to put my bike running on that tyre - unfortunately, only after the 23rd of June - which is when i come back from holidays)![]()
Nice way to use your tyre! In the places where i usually drive you'd never have a tyre like that! The normal thing is to have a perfect tyre on the sides and totally worn in the middle... and oh boy... I really like cornering... but in here is dangerous 'cause most of the mountain roads are not so goodHere's a tire with 1800 miles on it...
THat's a Bridgestone BT-010.
I usually get about 1700-1900 from them on the rear, 3500-4000 on the front.
It doesn't matter if I do burnouts or not, as you can tell from the pic, when the sides are worn, it's time to go dragracing!!
Not if you don't run curves......strighlining and touring it will be OK....as long as they are similar compounds.Hey Vripley.
The ratio I have gotten a few times is three rears per front. I wouldn't recommend replacing just the rear with a different manufacturer tire. Could cause some handling wierdness.
