I had the pleasure of spending a couple of hours with the big girl on the dyno last night. Must have done 25 pulls doing all sorts of exploring with this new and exciting unit from suzuki (Busa 08)
The one thing I did learn is the rumors I've heard of the mighty Busa's speedo having considerable errors at higher speed, may have no legs. After a few tests on the dyno with air pressure at 42psi, these rumors appear to be pure myth!
The dyno has a read out on the speed of the drum which is as accurate as a PoPo's radar gun. This is what I learned. At 60 mph the stock speedo is either nuts on or at least so close I could not physically see any difference. At 100 mph, it appeared the big beast was reading no more than 101 mph. At 160 mph the big girls speedo was reading about 162 mph.
The results of my experiment has me convinced the busa's speedo inaccruacy of some 10-12 mph is indeed a myth. While the busa is not deadly accruate at speed, it is indeed, very close with the bike in stock form and suzuki's recommended 42 psi in the rear tire.
