Suspension tuning advice needed asap
slow learner
I was reading this and when it says "5 clicks out", does it mean all the way from "H" and turn counter-clockwise 5 clicks towards "S"?
ONe more question. From this paragraph:
"Finally, the fork should be extended by hand, settled slowly, and re-measured. This figure is L3. Halfway between L2 and L3 is where your suspension would settle if there were no friction in the system. Static sag can be calculated as follows: sag=L1-(L3+L2)/2. Repeat this process to determine the rear sag--measuring from the axle to a point directly above on the frame for each of the numbers. If you have TOO MUCH OR TOO LITTLE SAG, dial in more or less (respectively) preload as needed."
How do you know if you have too much or too little sag?
Forget the generic bike suspension tuning. Read through this post from Jinkster & it will all make sense!
