traction issues
I had a traction problem at 9" over so i backed mine up to about 7" over and it hooks great now. The shinko needs to be good and hot to stick on the street but i can hit the juice out of the hole at the track and not have traction problems - couldn't even hit the juice in 2nd without wheel spin at 9" over.
EK ZZZ chains claim to be zero stretch, mine hasn't moved a bit since i had it installed. Try one since you don't have enough adjustment room.
OK I'm hooked but
Whats your rear tire air pressure set at??
Actually I should ask what was the pressure readibg before you posted and then what is it now that your hooked up?
air pressure about 20 lbs. just put on a 16 tooth front so well see how she does
theres a few things you can do to enhance better weight transfer to the rear
1 raise the front ride height
2 lower the rear ride height
3 soften the rear damping
4 stiffen the front damping
5 reduce front sag
6 increase the rear sag
just remember these will affect handling and dragging issues
good luck
