Wet Kit Nozzle Placement
This is my Wet Spraybar
This is my Dry Spraybar. Yes all mounting hardware is included
Both looks nice! :thumbsup: The dry one can later upgrade to a wet and those plastic lines are safe for fuel?
How much $ is for the dry bar kit and if you can make it with a round bar or hve to be with the square only?
I think it has better air flow.Round vs square ! OOOOO and by the way a frien have a square bar like yours i think is yours because is the same as in those photos but his had the 4 nozzels bend and he want to install in his first gen busa,how much will be for the nozzels? Thanks
I would have to see the spraybay. Send me a pic
how do you jet the nitrous and fuel with your spraybar?
The jets are installed into the showerhead. The Fitting for the Jet is mounted on the outside of the airbox so to change the jet all you have to do is lift the tank and remove the line.
