Have to agree w/that . I run 93 .Manual says minimum 87 octane. Minimum is the keyword there.
Please explain what the octane rating has to do with the way an engine idles?Manual says minimum 87 octane. Minimum is the keyword there. That means anything LESS than 87 may hurt the engine.
87, 89, 93 ... use what you feel is best.
As for me, my bike idles much smoother with 93. Aside from that, I feel no difference from any of the 3.
Your cars have ECUs with knock sensors that can advance or retard the timing based in the octane of fuel your using. The Busa's ECU is primative compared to whats in any modern car and it doesn't have a clue what you put in it. Timing is the same unless you modify it yourself (and then you better not go back to a lower octane).Well I used to run 87 in my car, then I tried 93 and it got alittle hoped up and ran stronger. So I used 93 in the bikes thinking its higher number its better. Then I read all the posts on the octane and the busa and found that 87 is what I should be using. But I just put in 89 yesterday and the bike felt stronger so I am just stick with middle ground :-)
If the explosion that happens in the cylinder is less violent, then certainly it'll idle smoother. Especially a Busa, with it's primitive ECU. Or my Ninja, with simple electronic ignition timing.Your cars have ECUs with knock sensors that can advance or retard the timing based in the octane of fuel your using. The Busa's ECU is primative compared to whats in any modern car and it doesn't have a clue what you put in it. Timing is the same unless you modify it yourself (and then you better not go back to a lower octane).
Since octane rating has everything to do with the fuel's resistance to detonate and nothing to do with a bigger badder more volatile explosion, "more power" or "my vehicle idles more smoothly" just doesn't work into the equation.
The amount of power produced by X amount of pump gas will be the same no matter what octane rating you choose. 87 octane will not make a more violent explosion, it'll just ignite easier. Higher octane is used to stop detonation (engine ping) and that happens when the engine is under heavy load conditions. Too low an octane and the fuel ignites too early, timing is thrown off and you hammer the pistons. Solution is to retard the timing and lose power or increase octane rating.If the explosion that happens in the cylinder is less violent, then certainly it'll idle smoother. Especially a Busa, with it's primitive ECU. Or my Ninja, with simple electronic ignition timing.Your cars have ECUs with knock sensors that can advance or retard the timing based in the octane of fuel your using. The Busa's ECU is primative compared to whats in any modern car and it doesn't have a clue what you put in it. Timing is the same unless you modify it yourself (and then you better not go back to a lower octane).
I have no idea what so ever. But then again I know rolling my right wrist causes the bike to speed up and slow down depending on the rolling direction. I don't know exactly what's going on internally, but I know that's what happens.Please explain what the octane rating has to do with the way an engine idles?Manual says minimum 87 octane. Minimum is the keyword there. That means anything LESS than 87 may hurt the engine.
