That would make long cruises a challenge wouldn't it
Haven't seen that pump anywhere recently.
OH BOY...loud and wrong
Q-16 is 116 Octane, C-16 is 117 Octane.
From VP's site
C16
Used in turbocharged engines, blown engines and nitrous applications with CRs up to 17:1. Recommended by the top nitrous oxide companies. Spec Fuel for NHRA Comp Eliminator.
- <LI class=fuel_list>Color: Blue <LI class=fuel_list>Motor Octane 117
- Specific Gravity: .735 at 60° F
NEW! Q16
Q16 will work well in any drag racing or circle track application -- naturally aspirated, nitrous or blowers. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating.
You cant get these at the pump, a local race-shop or try online. Be ready to pay about $75.00 for 5gallons. its not cheap.
Home >
VP Racing Fuel > VP Racing Fuel C12 - 5 Gallon
Price:
$65.00
Code:
VPC12
Quantity:
Vee Dub Parts is now stocking VP Racing Fuel. VP is the standard for racing fuels of which all the others try to copy. If you want to go as fast and consistent as possible, this is the fuel for you.
5 gallon cans of the following in stock ready for immediate pick up.
The best all around racing fuel made. Recommended for CR's below 15:1, satisfying the needs of the 75% of todays race of the winningest fuels in racing history, including Modified Tour, GNN, D.I.R.T., Indy Lights, NHRA, AMA as well as other national championships across the US and around the world.
Color: Green
Motor Octane 108
Specific Gravity: .717 at 60 degree F
THIS FUEL CANNOT BE SHIPPED! YOU MUST COME PICK IT UP AT OUR STORE!
