I think what the guys are getting at is that it's sorta up to you. If your experianced, and you've been practicing then right about 4-5K is Ideal. If your like me and you just wanna take the clutch outta the picture then I launch at about 2K and simply flop the clutch and get to work on the throttle... Avoids the whole ON/OFF Clutch issues the Busa has. May cost in 60' times but out in the streets it simply allows you to get on the power within about 10' of moving without fuggin with the clutch... Works just fine.
