I use the rear brake on the street, but I use it in combination with the fronts and only to augment the front.
Same here, just like I learned from several MSF (BRC/ERC/MSRC, etc.) classes over the years.
The rear brake is not all evil. It can be used in conjunction with the front brake to help balance the chassis and increase braking ability.
BUT, most suspension setups are not setup to balance the weight properly under braking. All of weight transfers to the front unloading the rear tire and causing a lockup.
Ask 100 racers and 50 use it, 50 don't. It really comes down to style and preference but more importantly, bike setup. Does your bike pitch forward a lot under braking or does it squat evenly front and rear? If you picked the latter you can probably safely apply the rear brake.
I use the rear brake on the street, but I use it in combination with the fronts and only to augment the front. I also use the rear to sit at a stop light and keep the bike stationary.
I only read about not using the rear brake on here, quite a while ago.
Been paranoid to go near the thing since.
Is there any time you can use the rear brake?.
Don't know I have a rear brake on the track...my skill level doesn't afford me the ability to know what to do with it there. As for the street, I use it for low speed stuff or sitting on a hill at a stop light or such to rest my hand.
WOW, my subscription notice is not working. i didnt think anyone had responded.
Anyway, i do this also. i drag the rear in stop and go traffic to balance the bike.
Yes, to help out the front in hard braking, IF you have the presence of mind.
On the track, if you EVER go off track, THATs when you want to use the rear to slow down. i.e you have a off track excursion in the grass, the rear brake is good for that, applied slowly, (if you have the time).
On my m109 I use the rear along with the front brake to stop you almost have too unless you wanna go through a stop light or sign, on the busa I typically used only the front brake cuz my buddies say you didn't need to use the back brake and that it would lock up the back throwing you from the bike. But for the last couple weeks I have started using both of the brakes and I like the feel of using both of them there isn't nearly as much dumping up front and it slows down much quicker giving me a feeling of more control
Darwin will catch up to that fool.... One day...
Darwin caught up with meSlammed my butt right down on the concrete. Learned my lesson though no rear brake.
Even when using the front brake too it will still lock up?
that depends. this depends on application pressure.
let me say this for clarification, your front will lock also. BUT with a heck of allot more pressure has to be applied to do this, especially on a larger bike.
The front brakes certainly have the ability to lock the tire on just about any modern sportbike. However, if you are applying the brakes smoothly on a dry surface, you are far more likely to lift the rear wheel instead of locking the front.
yup, i just did not want to mislead any new guys.
