David Offor
I think this should cover yours, make sure you connect the vtv round the right way, it's a one way valve, I believe orange part towards the front of the bike.
Just read this one again, have you tried a different or new fuel pump relay? They do become faulty.ok so i took it to a shop and we swapped coils, injectors, and still having the same issue. got to playing around in the shop and put it on the stand. when its got no load it will rev out in gear any gear. under load at 5k its like it hits a wall. if i hold it wide open i can get to 6500rpms but its like the fuel is getting shut off. im at a total loss right now and need some thing to look into any help would be nice.
Hi Valingt.
I'm happy to offer a path that I'd personally consider 'methodical' but I hope others will chime in too, as there's always more than one way to approach a problem and I'd focus on all the components, that could cause your symptoms (to the best of my knowelge).
Check engine timing
Leak down test
Compression test
Fuel pressure test, priming, cranking and at high rpm
Test injectors
Set tps correctly
Sync throttlebodies
After these initial tests the next steps will be checking your electrics and sensors, relays, wiring loom, ecu etc. You said you've changed the ckps with no change, you said that you've bypassed the fuel pump relay, its a tricky one. I've heard about side stand switches giving problems.
Like 'jermzfree' said, if you have a good local shop, it's probably worth picking their brains for info, rather than chasing your tail.
Are all the compressions the same or similar? If you have all similar readings and no leakage on the leak down test, imo, a topend strip down won't help you, unless you have a blown head gasket, can you do a test gota blown headgasket?
