Yeah, we checked the sensors too.(Spudley @ Jul. 22 2007,04:59) Nevermind...I guess it was the harness?![]()
Replaced the ignition pickup coil in the engine case, ALL the sensors, still no go. Even removed the airbox flapper valve thinking it might be sticking and restricting airflow. Now we're at the point of checking all the connections on all the wiring in the harness. My mechanic is the best as far as I'm concerned, but he's scratching his head too. He's even been on the phone to all his experts. This problem has not occured yet for anyone. My bike runs great right up until it hits 9k on the tach. Unbelievable.
( hey it's Dracula , my ,2008 busta is doing the same as you discribe , did you figer out why your bike is doing that ??View attachment 1184053 02' Sounds like the same problem - Runs Great at low rpms - City driving commuting- But run it up to 7000K in 1st thru 6 th gear fast and she farts out on me like she needs more gas- run it up till she farts out then let up a bit and roll on the gas a bit slower and she dose accelerate past 9000K - Me thinks fuel pump. ??No FI Light on error codes??
What have I done so far -
Cleaned and re-oiled Air filter (Ok)
Checked Throttle Body Vac lines and hoses
Checked Throttle Bodies Sync (Ok) used Morgan Carb Tune
Checked Wire Harness as best as I could without completly removine it- (Looked fine)
Load Zero Map on PC III (check)
No TRE (Nothing to Check)
Checked TPS (Ok)
Checked plugs (Ok)
Coils (Ok)
Injectors (Ok)
Throttle Bodies are a bit varnished ( ?? )
Yes I have gas (Ok)
Need to learn how to check fuel pressure ( Working on it)
But still think it is the Fuel Pump
( I change fuel pump the quad injectors too plugs oil clutch upgrade / well I have no high rpms,??( hey it's Dracula , my ,2008 busta is doing the same as you discribe , did you figer out why your bike is doing that ??
Hey ; just like to know if you fix your bike ??I have suddenly developed a power loss at 9k RPM and the FI light comes on. The codes are C24 and C27. I had the coils changed, the injectors changed, and the fuel pump changed. The next move is to check the magnet on the camshaft position sensor or replace the ECU.
Help!
, I will change the things You posted , t will let you knowI had what you are describing on my 2001 busa, it turned out to be a faulty crank shaft position sensor (ckps).
I posted 7 threads, showing all the things I tried, had me stumped but got there in the end.
Good luck.
