Johnnycheese
he says it is fine(Johnnycheese @ Jun. 16 2007,15:59) I say the cam jumped a tooth
His engine was rebuilt about 35,000 miles ago...the cams were put in them(Big Red @ Jul. 07 2007,20:20) New cams; what about valve train problems?
20/20 hindsight, I think this might be an easy check. Is it possible to check the other wires like this? Do you have to dissconnect the wires or can it be done with an induction sensor. Like a timing gun has an induction pickup?(stlbusarider @ Jun. 15 2007,17:01) If the FI light is coming on still after replacing the cam sensor you should have your tech use an occiliscope and ck the wave form on the sensor at 9k rpm. If he's as good as you think, he'll know what that means. If the wave form is erattic you may have a problem with the ring on the cam. Hope it helps, ggod luck.
