LOL that sums it up pretty much.what is covered under warranty = 100% manufactures defects
what is not covered
transmission ?
chain
brakes
tires
lines
clutch
i dont know what the hell is left
rear shock
forks
engine? knowing how they treated you with a trans , do you think they will cover a spun bearing? broken rod ? will they even cover a leak in the oil cooler? or tell you that its your fault you hit a pebble on the highway ?
radiator leak ?
what will suzuki cover on a brand new busa ?
or are these wear items ?
if your chain snaps at 1000 miles ? is it covered ?
fork seals at 250 miles covered ?
suzuki warranty
There is a few things the warranty covers...
1. Brakes, if the brakes fail on you when you're going 150 on the freeway, just whip out your cell. Call suzuki and they'll dispatch a tech to lasso you and slow you down.
2. Bolts, if a bolt falls off while you're riding, simply pull over, retrieve the bolt and bring it to your nearest authorized suzuki dealership and they'll put it back on for you free of charge. If you purchased the extended warranty they'll even buff off the dirt and grime with a terry cloth prior to placing it back on your bike.
3. Air, Did you know that you can get free air for your tire at your dealership if you're under warranty?. This only applies to suzuki oem tires during the warranty period. However, a little known secret is that even after you purchase aftermarket tires. Often aftermarket companies include air in their tires as well.
See if you know how to work the system you'll see there's a lot free stuff you get for you're 11,999$ bike.
Hell even the tax is included free of charge when you buy the bike.
