Mythos
If the throw in the brake pedal is getting longer until it just bottoms out and you have no braking at all at full throw, that is a hydraulics problem or possibly piston in caliper is getting stuck (but then your brake would also be dragging). If the throw remains more or less constant but the brake fails, that might be pads or rotor.
Because you mentioned a couple pumps brings it back, that suggests low pressure. You pump some down from the reservoir and that restores the pressure. That sounds like fluid leak or air in the line but the fact that the pedal comes back to 100% on its own tells me otherwise.
It sounds like the brake works but the pressure is not returning to the master cylinder after you release the brake. In other words, the caliper is remaining closed after you release the brake pedal. The brake pads would be dragging the rotor. You might not feel that with the weak back brake especially carrying a passenger.
First test on a rear stand. Spin the rear wheel. Does it spin normally or is the brake dragging? It should turn one full revolution in Neutral if you give it a good spin by hand. Then apply the brake a few times. Does it stick after the brake was activated? Yes? caliper piston is sticking. No? Continue to work the brake pedal and spin. Can you duplicate the problem? Yes? Caliper piston. No? Do you loose pressure in the pedal but the wheel spins freely? That has to be air in the line or a bad master cylinder. It's also possible that the problem would only happen when the system gets exceptionally hot from heavy use. Do a road test.
It's normal for a rotor to get hot to the touch after even after mild use. Try riding the bike and applying the brake just one or two times. If the rotor feels hot after a few minute ride, it might be that your caliper piston is sticking. Try putting the rear up immediately after the test ride and see if the wheel spins normally.
PITA but you could disassemble and clean the whole caliper and pistons and replace seals. That is a part of sched maintenance. My bike has 11000 miles, I've never done it. The Kaw has 47000 miles and no rubber parts replaced yet.
The rear brake is the easiest thing to bleed. Don't TIGHTEN the bleeders during bleeeding, just barely snug is enough and you won't wear out the threads. Watch for seepage in the days after the bleed and wash away with water often. Give it a tiny crick more torque if necessary. DO NOT overtorque the bleeds or the threads may leak even with new bleeders. It's not unusual to have seepage weeks after opening the bleeders and that is why I don't bleed unless I really need to. They often seal up on their own after a while but wash away that seepage often because it will etch paint.
Read the intro and steps 13 to 21 here:
https://hayabusa.org/forum/threads/genii-front-and-rear-brake-fluid-clutch-fluid-bleed-drain.170084/
I hope that helps solve the problem. It's all I got. I don't know much about master cylinders yet.
