I'd love to punch the guy who decided to put the front bleeders on the inside.
...that's those fancy Brembos
Major pain. Offset wrench won't work. Only thing I could get on there was a very short wrench. Brakes are drained. Ups bringing lines and pads today...that's those fancy Brembos
Front lines are in. I'm guessing I need to pull this rear set off to get access to the rear?
Will be doing this morning. Thanks
IndividuallyAll the lines are on and bleed has started. Using a Bikemaster vacuum pump.
Should I bleed each front caliper individually or at the same time (tee fitting)?
Well, now my compressor is acting up and my mityvac is rusted out. Guess I'll zip tie the lever until I get a new mityvac tomorrow.Individually
I don't use EP and my bike stops just fine even when coming into apexes sort of hot and needing to scrub speed....never had any fade or issues.Looks like I need ebc EPFA447HH or just FA447HH. I can get the regular ones tomorrow from Amazon but it's going to take like a week to get the EP version. Thoughts?
I agree. ThanksI don't use EP and my bike stops just fine even when coming into apexes sort of hot and needing to scrub speed....never had any fade or issues.
Unless you plan on doing track days regularly, EPs are overkill.
The EP's make a noticeable difference, and they Will stop you sooner.
That Does make a difference...wait until someone pulls out in front of you, then you'll be grateful for every ounce of braking that you can get
I've done many fast braking situations with the pads I have with zero issues....The EP's make a noticeable difference, and they Will stop you sooner.
That Does make a difference...wait until someone pulls out in front of you, then you'll be grateful for every ounce of braking that you can get.
The decision is yours....check out EBC brakes.com and compare and then buy...Good point. So many decisions. Lol
This what I ordered last pad change I did:Looks like I need ebc EPFA447HH or just FA447HH. I can get the regular ones tomorrow from Amazon but it's going to take like a week to get the EP version. Thoughts?
