tourbus
uhhh noooo, change the oil @ the recommended service intervals, suzuki is not going to tell you to do something that is going to hurt your new motorcycle. your wasting your time and hard earned $$$ changing oil @ 100,200,300,even if you change it early your still going to load the new oil up with debris so why not leave it in there and let the oil filter do its job, also with todays quality of metals and engine assembly there is no need for super frequent oil changes unless your plowing fields or taking it down the drag strip every weekend. i agree with motorcyclist magazine and suzuki, change the oil at 600 miles,because if you do a bunch of oil changes before that or add synthetic before that you may actually impede the engine break-in,they also went on to say that most motorcycle engines are broke in by 2000 miles. i personally change the oil at the recommended intervel than change it again at 2000 and at that time i will go ahead and put in my oil of choice (mobil 1 4t)I would change it before 500 miles do it at 100 and again 250 then 500 theres lots of shavings in there![]()
