cleaning my rims
texomawaves
How do you clean yours? I think I'm getting a little chain grease splatter and want to carefully remove it. Thanks!
First thing is to change your chain lube to a wax or one that is dry like DuPont Teflon spray.
Then use either WD40 or some Pledge furniture polish to clean the wheels.
Formula 409 or Fantastik gets my wheels clean. I follow up with Maguires detailer to make them shiny and streak free.
I am a K-1 guy myself use that stuff for everything. Clean chains, lube splatter, tar off my truck, air filters on the MX bikes, All the nasty mess my son's 2 stroke leaves on the can and frame. Best thing is the stuff is really cheap if you use your own can and can find a station that sells it fo a pump.
