i went with the 6000 low beam and the 4300 high beam
the 6000 has enough of a bluish tint that it stands out when i am running through town and other drivers definitely notice it so they don't pull out in front of me
i do a lot of riding at night so i went ahead with a high beam...as the bug noted, the 4300 puts out the most light and it is a more natural color than the higher temp bulbs
i can definitely tell a difference when i flick the high beam on...the HID low beam lights up the road better than the OEM low and high beams together...however, the HID high beam is unbelievable...road signs will start to glow before you are even close enough to read them (and so will little eyes next to the road and in the edge of the woods)
one word of caution on the 4300 bulbs...when i was researching before i purchased mine, i was told not to buy the 4300 low beam...apparently, the color of the light it emits is close to the same color as the sun...if you are riding at sunrise or sunset and happen to be traveling with the sun behind you, your light blends into the sky behind you and oncoming traffic will not spot you as easily
