ELECTRONIC CRUISE CONTROL FOR BUSA'S
Well this is the second time for me, so hopefully it works.
Def, didn't take half the time to install it this time around.
Seemed to of got it working.
Took it out for a 3 mile ride and seems to hold speed.
I'll get to check it out better later.
Just one.
Seems to work good.
I'm going out in a few minutes to test again.
Need to wire in a relay to work with the LED taillights.
So far so good.
Need to get that relay to work with the LED's.
Right now the cruise only shuts off manually or by pulling in the clutch.
After that the install should be perfect.
Thanks for the update. One of these weekends I'll get around to doing mine. Hope the first time is a charm
I'm very interested. Keep the posts coming guys. BTW pipefighter, did you ever get that belly wing?
Pic of the control pad mounted.
Right under the bar, can reach with middle finger with hands on bar, or easily take hand off bar to operate.
pipefighter could you give a parts list and how you did it. please.:) and how did it work out with the led tail lights. i`m going to do this also. thanks
Good luck Nathan...I was getting ready to check out the site for more info when I saw the luck you've had so far...
