All right! Finally removed and cleaned injectors. Backflushed first with carb clean and makeshift hoses small to big and on/off with 9 volt battery. 1 injector seemed a little clogged but all 4 spraying good now. Cleaned and blew out rail and line which were fine. Put back together and still no start. Removed tank again and fuel pump assembly would not come out??? Found new regulator cooked to one side causing it not to come out. Popped it off inside of tank and removed all including clear clip. Must have fell off and caused pressure loss. Took apart pump assembly and checked all. All seemed OK. Put all back together this time with zip tie over regulator and clear clip and blew 40 psi into filter housing. No leaks. Went to put in tank but zip tie would not pass through opening. Cut off and triple checked clip was secure. Put in tank and tank on bike, primed 3 times and started immediately. So long story short. 1st pump-junk. Second pump good, but regulator dislodged somehow causing low pressure. What a pita but runs great now. Thank you for your help guys, I learned alot about this bike. It's really not my style of bike so I'll ride it a few times and may sell it. I stumbled on to this bike for a great price with some work needed. So just wondering how much it's worth at this point. 4k miles, all new plastics not perfect by any means but nice bike. Flushed all brake and clutch lines and just changed oil and filter. New battery, air filter, tires are old but you would never now by looking at them, almost new tread but need replacement regardless. Beleive it's stock with Broks exhaust.
