Thank you so much my man.
All the love to you.
Well if the bearing and the crankshaft looks good then should I just repack the bike and get it back home?
Yes sir, I would get it home and away from them.
So to be honest my bike has been well maintained.
Never abused.
It’s just heartbreaking for me.
I had a couple of days for my vacation back home and it’s just been sad and depressing ever since this incident.
I hope we all get together and find a solution.
Also I asked him about the rectifier he said it’s working ok.
You've probably done some research on this via the internet..So to be honest my bike has been well maintained.
Never abused.
I had already mentioned these parts to my Suzuki mechanic and he already replaced it with another new part and tried if itd work but it didn’t.You've probably done some research on this via the internet..
I found a couple videos on gen 1s with starter clutch and shaft issues for you to look at as well...I'd imagine the mechanisms are similar in the different generations
The first one shows wear in the shaft that binds the mechanism causing it not to turn....
Google Search
www.google.ca
Google Search
www.google.ca
Cool then il do that.Yes sir, I would get it home and away from them.
Could there be an wiring issue that’s causing this? Or binding when the bike’s warm?
You mentioned he replaced the starter clutch, the pin these guys are talking about is in a different spot....your mechanic may have not even checked to see if this was binding.....I had already mentioned these parts to my Suzuki mechanic and he already replaced it with another new part and tried if itd work but it didn’t.
To be honest I don’t trust any mechanics words.
...just spit-balling ideas to get you sorted out..
It could be possibleI have had this issue on my 2nd gen. Bike would start fine cold but if I stop for gas it would not turn over fast enough to start. Sometimes to get it running I could put the bike in top gear and roll the motor over, and then it would start. This could possibly be a fuel vapor issue or injectors leaking fuel, so turning the motor over would vent the vapor out. The fix for me was actually a new battery, I had good voltage but was lacking the amps. Also, make sure your grounds are clean and tight.
Watch those videos as they aren't talking about the starter clutch per se but the shaft for the pinion gear that has movement in it causing it to bind.Yes he checked the starter clutch as well .
He put in a new one and it didn’t fix the issue.
Yes I mentioned this part today when I was at the dealership. And he told me checked it yesterday.Watch those videos as they aren't talking about the starter clutch per se but the shaft for the pinion gear that has movement in it causing it to bind.
This may or may not be the issue but it is another step to process.....if your mechanic of whom you don't necessarily trust has checked this, it might be worth checking again or get the dealership to check this shaft while they have the engine apart...
Good, that's something checked off the box at least.....Yes I mentioned this part today when I was at the dealership. And he told me checked it yesterday.
Hey I was wonderingYes sir, I would get it home and away from them.
If the bearings are not good at that mileage, then whatever caused that, will have damaged the rest of the motor. Those are not just take out and replace items. In short, if your bearings are shot, the bike must have overheated badly at some point, or something else, and the entire motor should be redone.Hey I was wondering
Should I just get the bearings changed?
24 volt battery?I still standby the starter swelling from the heat of the engine making it turn slow. I'd try DEI gold tape on the starter before I did anything else. If that failed, then I would go 24Volt and it'll crank away like no tomorrow.
HiIf the bearings are not good at that mileage, then whatever caused that, will have damaged the rest of the motor. Those are not just take out and replace items. In short, if your bearings are shot, the bike must have overheated badly at some point, or something else, and the entire motor should be redone.
If you don't have experience with the technical details, best is to get a service shop where you have more confidence in the technicians.
Hey man I even put in a new starter. But it didn’t work.I still standby the starter swelling from the heat of the engine making it turn slow. I'd try DEI gold tape on the starter before I did anything else. If that failed, then I would go 24Volt and it'll crank away like no tomorrow.
I wouldn’t think it would if it’s swelling them from heat. Like I said above it’s like $15 for the tape to try it out or just go 24 volt. You use two batteries. One is isolated to only go to the starter so only the starter sees 24volts everything else on the bike sees 12volts. It’ll spin that starter so fast you won’t believe the sound. I’m sure there is a thread here. I think I made one when I did it.Hey man I even put in a new starter. But it didn’t work.
