cool…. But what’s the situation with the 2nd battery’s charge state?
It would be necessary to charge the 2nd battery every now and then due to it being isolated from the bike’s charging system would it not?
Unless a person is running uber-high compression, Suzuki didn't design the Hayabusa to run such a system.....if one is needed on a basically stock bike, there is a real problem, one that needs to be resolved, not over-powered...
Unless a person is running uber-high compression, Suzuki didn't design the Hayabusa to run such a system.....if one is needed on a basically stock bike, there is a real problem, one that needs to be resolved, not over-powered... Just
I completely agree with you. That’s why I recommend the DEi tape. I really think on some bikes the tolerances are tighter than others in the starter and the heat swells the parts making it harder to turn. It would explain why 24 volts or a larger battery is able to overcome it. Keeping the heat out of those starters that this happens to is my first recommendation. I could be completely wrong but it makes sense to me.
Hi
I spoke to an other mechanic from here and he referred to just change the bearings. He says no way your crank is shot. He has seen my bike first hand and personally.
And he asked na a question I could not answer confidently, which was if my radiator was serviced or working perfectly.
Coolant should be flushed every 2 years, it is regualr maintenace.
A simple procedure, and you can buy coolant flush in the store, but distilled water and white vinegar work just as well, if not better.
One to two flushes until the water/vinegar runs out of the engine clear, then refill with coolant, 50/50 premix, or better yet, Engine Ice.
It seems you tried every other suggestion on this thread except replacing the bearings.
I have a 2015 Busa with the same problem. I ruled out the kickstarter and battery as the cause. Two mechanics have told me that it is the bearings that need replacement.
I am still researching a probable cause to this annoying problem, which led me to this thread.
