No one knows
I'd say gen 3 specific aftermarket parts will be coming in droves shortly the same as they did for the other 2 generations...the issue with the release of the gen 3 is it came smack dab in the middle of a pandemic.No one knows
Bumping this from the dead instead of a new thread.
With having a wave rotor on the rear and stock up front, it's already bugging me so doing some searching to see if an upgrade was available yet. It appears the Gen1 99-07 was also 320mm. I believe this was pre-Brembo front calipers, but IF the ID and thickness of the Gen1 rotor is the same as a Gen3 we could potentially could use them.
Thoughts?
Bolt spacing too.
Is this what you are needing?
Not alot of material left between the buttons and the I.D.
I hope it fits or only needs a few thousands turned out.
Another cool idea either way.
