Build a new map. Remember when you do , Air, Fuel , Timing. Get the ratios right. When you start opening the stp's up, And put a lot more fuel, And timing in it the bike will run completely different. It will be a lot easier to ride and pull a lot harder. I did not like the stock settings at all. Its like you can ride it easy or you can let it rip. it takes a long time and a lot of maps. Suzuki would crap if they knew what I did to this thing.
This is horrible advice without a wideband. Unless you doing pulls and going through a small fortune in plugs you have no idea where your tune is at.
