You do steels also?
Drain, flush, replace fluid. Remove, check, and replace worn fibers and bent/shiny steels.
Keep in mind he stated it’s doing this before and after replacing the parts.I understand that. However it's far more likely that you made a mistake installing it than it is you're experiencing a problem that nobody else has had, at least that nobody here has ever heard of. So, take everything apart and put it back together, make sure you didn't put the drive and driven plates in the wrong order for example, make sure the basket isn't cracked, make sure you haven't contaminated the fluid etc.
I know you're frustrated, in my experience with these type of things it's usually something simple that's been overlooked.
This is my thought as well. Something not allowing fluid to return to the reservoir/MC.Is the clutch lever itself stock?
Some of the aftermarket levers(or a damaged stock lever) do not allow the pin from the master cylinder to seat correctly.
This can cause the clutch to not fully engage or disengage.
What did the clutch plates you removed look like? Were they burnt, or worn out of spec?
I get that, but it doesn't mean it was done carefully and/or correctly. I'm simply suggesting that throwing parts at a problem you haven't accurately identified can get costly in a hurry. Ask me how I know this.....Keep in mind he stated it’s doing this before and after replacing the parts.
I’m 100% with you on the throwing parts thing.........! It adds up quick.I get that, but it doesn't mean it was done carefully and/or correctly. I'm simply suggesting that throwing parts at a problem you haven't accurately identified can get costly in a hurry. Ask me how I know this.....
If I had already spent that much on parts, I would just spend another $20 on a used master cylinder on eBay and swap it.Clutch lever is stock. So is it safe to say that the hydraulics in a clutch somewhere is going wrong?
I'd say it's far more likely that something mechanical is going wrong. You keep focusing on the hydraulic element of the clutch, when that is just a small part of the process. Not being a smartass, but do you understand how the clutch mechanism actually works?Clutch lever is stock. So is it safe to say that the hydraulics in a clutch somewhere is going wrong?
Are you doing the work yourself, or is someone else doing it? A shop etc....
Are you sure it has something to do with heat or could it be the amount of clutch pulls?
Wow, ignore my earlier post. I didn’t realize that when you said MAster cylinder was OEM, you meant it was a new OEM, instead of the original one.I did some of the work myself at 1st, then I got the bike trailered up to the shop then I paid the shop to do the lastest work, master cylinder, clutch lines, slave cylinder and push rod all OEM. Which was their recommendation because I could have "messed something up".
After a week, they completed the work. All the new recommended parts and they inspected the clutch fibers, steels and said they was good and stacked correctly.
did the test ride and said "Everything is working great! How would you like to pay?"
Of course it was riding great when I was riding it home, then ran into the same problem. Working perfectly fine until the bike got hot enough, then the clutch slowly started slipping then stopped working all together (hit the throttle, just rev and no movement, like the clutch was fully disengaged). Until I pulled over and let the bike cool down, then she was good again.
Took it back up to the shop (after the cool down) so I can simulate to them what was going on. Was even able to show the guy that was working on it, the problem. He was puzzled. They didn't know what else to do to her.
So I was stuck paying for parts and labor that didn't fix the problem.
Maybe the shop Overlooked something too
It sounds like, from that description, that the plates are slipping. Can you disassemble the clutch and take pictures of the steels? I'll bet they're glazed over.
Fwiw if I had a shop fix my bike and what they did failed to fix the problem, there's no way I'd pay anything, until they actually fixed it. That's just me though....
