Mathewrussell52
I’m racking my brain so I pulled out service man and read all the clutch section. Maybe weak clutch springs or pressure plate is in the diagnostics section.
I'm a newb but did you soak the clutch plates before putting in? Thought I read that needs to be done in a wet clutch setup.
Motor oil at correct level?
Well that's about all my knowledge, good luck. Bikes not making crazy power that you need heavier springs or anything right?Yes, the clutch fibers and steels was soaked overnight. Correct level, yes.
That's fair, parts are not returnable once installed...I'll have to do that once I get a day off. They did end up giving me a refund for most of the labor with the exception of inspection. But the parts I did have to pay for.
Letting out a little fluid isn't going to significantly cool down the rest....
So, again, fluid temp isn't your issue
I am dying for a way to fix this issue! I'm damn near ready to just get rid of the bike and get another Busa.
If you read his original post on this problem, he overfilled the master cylinder reservoir when changing the clutch fluid. When brake fluid heats up it expands and needs somewhere to expand to. If the reservoir is overfilled the fluid has nowhere to expand to! Pressure builds up and bam! slipped clutch. That's my theory anyways.
When did this start?
Out of the blue?
After you bought it and first started riding it?
After Any other work done?
So you are absolutely sure you used dot 5.1 and not dot 5? As the almighty google says 5 is not compatible with 4, but 5.1 is. And are you sure you got out all the old fluid and filled the reservoir to the top of the bubble? I would try re flushing one more time. Don't worry man!
I would check the sprocket cover.
The cylinder that the piston fits into.
Measure it. Any burrs or damage?
Also the hole the pushrod goes through.
Given that different metals expand/contract at different rates, there's a slight possibility that as it gets hot, the piston and/or rod is sticking from previous damage.
That's all I got for now.
I put the drive and driven plates in the wrong order "ONCE"..The clutch never fully dis-engaged..
