It was a clutch bolt grinding on the cover. It never cranked to get around anywhere really. Or at least that's what I'm telling myself..Should be good......
But for real I would expect it to live very long. Even if you changed oil 6 times .
Someone here said think it was @Kiwi Rider? If you took everything apart can guarantee every oil passage get cleared. So I took it as clean pick up filter and run it. Maybe it blows maybe you should of played the lottery.It was a clutch bolt grinding on the cover. It never cranked to get around anywhere really. Or at least that's what I'm telling myself..
You didn’t get chucks and a million flakes by it falling apart when it was not running.Out with the oldView attachment 1631366
The motor literally never turned over. Crossing my fingers..
Good luck with that motor, you are gonna need it!When I crack the cases apart it's getting dolled up.. just hoping it's later rather than sooner so I can save up enough.
Exactly what I was thinking.You didn’t get chucks and a million flakes by it falling apart when it was not running.
I think this is right, I wouldn’t chance it.You didn’t get chucks and a million flakes by it falling apart when it was not running.
That must have been making a hell of a racket before the bolts totally fell out
How many miles is on that bike
When u ask a question if you put the @ in front of the name like this @Berlin Germany it'll notify himBerlin Germany, can't find 1303 thread lock, would you use red or blue thread lock. Also would you apply thread lock to the clutch spring bolt as well as the clutch spring support bolt ,as it only says apply it to clutch support bolt and tighten to 23nm,
