Begin by removing the fairing side panels, seat cushion and fuel tank.
Note: Fuel Tank Removal isn't necessary but I recommend it for those who need lotsa elbow room....otherwise?..you can use rope or bungees attached to your passenger grab rail to elevate the tank high enough to get the job done without having to work around the prop rod..and again while not necessary?...I also recommend use of a quality rear stand.
Next?...remove the airbox by...
1. removing the front mounting bolt and..
2. the screw on the rear holding your vacuum sensor in place and..
3.disconnect the crankcase breather hose. Then loosen the two boot clamps screws (1 on each side) like so...
Then just wiggle and lift up to remove your airbox...Then?...
Loosen thes throttle body clamp screws about 15 turns then just gently wiggle the brace of all four T-bodies while pulling upwards and viola..the T-bodies are liberated..set them aside in a clean safe area.
to be continued...
to be continued...
