I make them for gen1 and gen2 busa so you can shut off headlight if wanted to save current usage, or whatever reason, key on for extended periods and want it off. Anyhow i could make a plug and play setup for gen3 as well. The actual head light connector is the little white triangular 3 pin connector buried up under the dash, not sure if you can get to it by removing the plastic under the headlight easily or not, i could do a plug and play connector there, or i could do it at one of the 13 pin connectors over the left ram air tube. this might be easier to access, but the connector is more of a pain for me to wire an inline adapter to.
