Heads up:
Though my arm looks great, I found a problem that I CAUSED!
never do any welding even if its light welding on an arm with out it being in a JIG. That new brace ...thru heat cycling...bent the arm in two places causing my 330 to now be off center to the LEFT by 3/4 inch.
The arm is now on its way out to KOSMAN to be jig tweeked back in place, redo the bracing, and make a inarm air tank.
I should have kept to my orig plan and just mount that brace, but to the top cover plate making it LOOK like it was part of the arm.
Nice setup.I like the OSD better than those jack shafts.I cleaned the crap out of my new chain hopefully for minimal grease slinging.Love the blue since mine is blue.
I was just wondering where you picked up the outside drive assembly? I'm looking into fabricating my own single sided swingarm for a 360 rear wheel but I HATE the jackshaft system. Any help would be great. I've tried contacting Kosman but they tell me to go to Roaring Toys... Kosman says they fabricate a zero offset pulley??? Thanks!!!
