I don't know, Charles. Like I said, I've been using it excusively for over 12.000 hard miles and only adjusted my chain 3 times. So far so good.......(Charlesbusa @ Oct. 22 2006,00:14) If you use wd40, I recommend one of those automatic chain drippers/lubers or lubing it with wd40 every 50miles. I wouldn't trust wd40 for more than 50miles.
I use chain wax exclusively. Got 19000 miles out of the stock chain. I ride rain or shine.(Greg B @ Oct. 22 2006,07:30) I'm sure there are some good chain lubes if you want to use one but do be careful of the "sticky" lubes that attract dirt and hasten your chains demise.
(brendanp @ Oct. 22 2006,10:13) I usually use a stick of unsalted butter....
J/K I'm using the Motorex spray.
I'm pretty happy with PJ1 Black label.(Greg B @ Oct. 22 2006,05:30)I don't know, Charles. Like I said, I've been using it excusively for over 12.000 hard miles and only adjusted my chain 3 times. So far so good.......(Charlesbusa @ Oct. 22 2006,00:14) If you use wd40, I recommend one of those automatic chain drippers/lubers or lubing it with wd40 every 50miles. I wouldn't trust wd40 for more than 50miles.
If you've ever replaced an o-ring chain you know the lube is captured between the o-rings inside the rollers so you're really not lubrication the chain per-say by using chain lube. The important thing is to keep the o-rings and chain clean of dirt and grime that is it's enemy.
Frisbee.. dont worry about it, you only need to lube it like once every 500 miles, so you have another 9 months to go..(frisbee @ Oct. 23 2006,21:58) Your supposed to lube the chain?? I thought that was a just a myth!!
