crash_matt
Update - Parts Arrived!
So, imagine my frustration - I order the parts, wait forever and even get to the point of ordering a second hand one off Ebay, figuring that way I can be getting on while I wait. Well, no sooner do I place the Ebay order than my parts arrive... hmm.. so now I have a spare pump!? Bound to need a clean when it gets here, but could be handy to have on the shelf. Now to the rebuild...
I had all the o-rings, a new fuel tap, all the filters etc and it was a fairly straightforward job of fitting them into the pump housing with the pump. Not too challenging and no point taking photos to post as frankly any arse-hat can follow an exploded parts diagram so let's not be too insulting.
One I had that all rebuilt I knew that the tank was going to need a scrub - so far I had taken off the fuel tap and that was all. I put it back on and filled the tank with evaporust. Yes, that's right - filled it. Best part of 25 litres - never mind the 21 litre capacity, it just keeps going. I left that overnight and drained it off via the fuel line from the tap. I did pick up some hose clamps for this job and they made it much easier. But do note that it is possible to buy an actual tap that will fit, which would probably be even more helpful.
I didn't get much of a chance to check what was coming out as it was going straight back into the plastic tubs it came in (you can reuse the stuff). It was in there for about 18 hours in total.
I then took out the sender unit and had a poke around with the endoscope. It was clear that there was an improvement BUT there was still sludge and cack in there. Now this is all down to being left with a low fuel level for a long time. For those who don't know (I didn't) the ethanol in the fuel soaks up any water in the tank/air and it turns to a nasty brown sticky mark - this was the stuff on the tank skin. Added to that when I started blasting it through with a jet wash and soapy stuff out come lots of yellow gel/snot. On top of that an absolute ton of flakey cack just kept on coming out.
I threw in some gravel (20 small stones - so I could count them back out) and shook it around, then wished I never had. It's a total c*** to get back out! I spent the next half hour chasing one bit of gravel out, only to then discover after another jet wash that there was another bit in there still hiding! At that point I did debate other approaches to clear things out even more, but the advice was a bit varied and frankly the more I just kept on rinsing and running it through the better it got. That and a bit of finger in the hole...
Anyway, I got the tank to the point of being as clean as it was going to get, dried it out with the compressed air gun and added some WD40 to help tackle the last tiny beads of the wet stuff. During the course of all this the following bits of tank damage occurred:
1) tiny, tiny scratches where it lay upside down on some of the grit that I blasted out.
2) the tank protector (which had been fitted off centre f***in amateur job) cracked and lifted - so I had to take it off revealing tank in need of a clean, rub down and a new pad.
3) the tank was sat upside down on a rag which has soaked up some of the petrol when originally emptied. Unnoticed at the time when I picked it up to start this faff the rag was stuck to the filler cap and when gently pulled it took some of the cap paint off, leaving a bloody mess. Might have to find a replacement or just rub it down and put on one of them sticky things.
Right, back to the job at hand. I put all the parts back on and offered the tank into place above the shiny pump. At this point I have:
Dropped the tank back into correct position, rebuilt the bike, added more fuel and went for a ride - just a short one. No problems so far and smooth on the power all the way up as far as I could go.
OK - so I am still waiting to use it in anger and to get the thing 'hot' as I know that can contribute, but it may just be fixed....
Fingers crossed all - if there are no more posts I fixed it and forgot to come back. If there are posts below - something has probably not got right or I've got more waffle to share.
Hope this has helped those of you who may be reading it in search of answers for your own dodgy running. At some point I will dare to look at the mountain of receipts and let people know what I spent fixing thing issue! But I'm not ready to cry yet - let me at least get a bit drunk first!
- Changed the spark plugs (now on CR9EK as it was all they had in)
- Rebuilt the pump contents
- Cleaned through the injectors using the motion pro injector cleaner
- Renewed the fuel pipes as the words of wisdom were that these like to get kinky and not in a good way - so while I was in there...
