No PC3, and the fuel pump is new with a new filter. That should solve the fuel pressure problem. The codes are for ignition pick coil (replaced) or low battery (replaced also). The codes in the manual say: CKP sensor (pickup coil) signal is produced but signal from ingition coil is not produced continuous two times. Ignition coil, wiring/coupler connection, power supply from battery.
I just talked to my mechanic and he's stumped. He's replaced every component on the bike. Had three experts he knows all working on it and they can't figure it out.
What's this about the clutch switch wired together?
Called the mech again, the wires to the coils have been checked and the clutch switch was checked, all good.
thanks
