wreckwriter
Static sag is 6, rider sag is 21. How do I increase it? This is rear, measured with Slacker
Thanks. That's what I neededI havn't used my Slacker yet, but sag is adjusted by Preload.
The lock rings on the top of the rear spring, and the hex on top of the forks.
Loosen to increase, tighten to decrease.
Forks have 5 visible reference lines if you back them all the way out, but count the turns to keep both forks the same.
Count the visible threads above the top lock ring on the rear for reference.
3 threads visible is a good starting point.
Read this several times, kind of confusing to meThis is an oldie, but still a great write-up.
JINKSTER ATTACKS "SUSPENSION" | Maintenance and Do-It-Yourself
This long post is for those of you who may be like me and use/ride your Hayabusa as "The Ultimate Hyper Sport Tourer". While the Busa is blessed with one he11 for power engine it's stock suspension leaves much to be desired by the curve slicing road warriors amoungst us. To wit?..it's front...www.hayabusa.org
You may also find you need to respring your front end as you are on the heavier side...I had to..Thanks. That's what I needed
Yea, I ordered a brass drift from Amazon. I have a shock spanner but can't get enough room to turn it. I assume the adjustment should be made with the wheel hanging in the air unloaded?Can you get a piece of 1" brass rod from a local machine shop?
Brass won't damage the lock rings.
If you pull the shifter side rearset off it makes it easier to adjust and it's only the 3 allen bolts you have to remove to get it out of the way.Yea, I ordered a brass drift from Amazon. I have a shock spanner but can't get enough room to turn it. I assume the adjustment should be made with the wheel hanging in the air unloaded?
Thanks. I'll try thatIf you pull the shifter side rearset off it makes it easier to adjust and it's only the 3 allen bolts you have to remove to get it out of the way.
I run 20 of ridder sag on the rear and 32 in the front. Your numbers seem great for road racing. What kind of riding do you want to do with your bike?I got the front dialed in but I need a longer punch for the rear. I only managed to get it to 24. Amazon has long punches.
If nobody has mentioned it, the static sag will tell you if you need heavier springs or lighter springs. If you have to crank the preload so tight that you lose to much static sag to get the right rider sag you need stiffer springs. That works in the other direction as well.Static sag is 6, rider sag is 21. How do I increase it? This is rear, measured with Slacker
Just streetI run 20 of ridder sag on the rear and 32 in the front. Your numbers seem great for road racing. What kind of riding do you want to do with your bike?
