Secondary Butterfly valve not opening according to throttle
Dafeimao85
Hi All,
I manage to retest whole bike again
I guess I found the reason why my engine bog
What happen as per topic it's not opening
When I on the engine, the butterfly valve went to 100% open. When I start it close and maintain at close position. No matter how I Rev the engine it remain close. After I off the engine, the valve then open back to 100%
Primary TPS voltage is working correctly. Ecu is getting TPS data but somehow the stva is not responding to the TPS.
Anyone has any idea about this? I try to Google but found nothing.
Make sure you are at an RPM and throttle opening that will open the STP enough for you to see. Reference STP map below.
