Rock,
Thanks for a real world testimony!
I too, have run 1 rotor on the street with NO problems, but then again, I don't allow myself to get into stupid situations where I may get run over. KNOCK ON WOOD! While anything can happen, I do my best to avoid trouble.
The only thing that I didn't like was that my lever got a little stiffer. But here's 1 for the nay sayers.
I can still skid my front tire with 1 rotor.
How much more STOPPED can you get? If the wheel is not turning, it doesn't care if it took 1, 2, or 3 rotors to stop it.
I'd be willing to bet that of everyone on this thread that says how stupid or dumb it is, that edubb1971 is the only 1 that has actually TRIED IT, and doesn't like it, and his experience was on a ZX-9, and not a Busa.
So the rest of these folks are talking about something that they have NO experience with, just guessing.
Sloto200 had the only negative answer that has had any merit. I've never thought about that kind of result. I would love to see those pictures Sloto, if you can round them up.
My remarks aren't to piss anyone off, but if you have real world experience why something does, or doesn't work, it seems that your opinion would carry better to help someone make a decission.
If you decide to remove 1 rotor, just keep everything that you remove, it's easy to put back on and doesn't cost 1 cent to do.
If you don't like it, put it back on and you haven't lost anything but some wasted time.
The long brake hose is routed to the right caliper. It has a long banjo bolt that recieves the oil to the right caliper, and delivers the oil thru a short jumper hose, to the left side caliper, and is bolted to the left side caliper with a short bolt. Remove the long bolt, reroute the long hose to the left side caliper and bolt it to the caliper with the short bolt that already goes into that caliper. Keep the rotor, caliper, jumper hose and long banjo bolt on the shelf. It'll be there if you don't like the single rotor.
The green bike went 193 mph in the mile, and the blue bike went 203 mph. Neither bike had a problem stopping.
The Texas Mile is also noted for a short shut down area.
192 at the Texas Mile
