Mobil1, +100. Suzuki puts thier name on somebody's oil, the don't have thier own oil factories.
Whats changed? ???
You can change your oil when ever you like. Everyday if you wanted to.i'm so anxious to try the amsoil in the busa and see how much smoother it runs/shifts. Right now i'm about 2400 on the clock, do u think it's critical i wait until 3000 or would it be fine changing it at 2400 to full synthetic
I think he is asking if it is ok to go to synthetic oil with only 2400 miles on the bike? I don't know how long you should wait. I waited until I had 18,000 miles and then went with Motul, it has worked out great so far. I can definitely tell the difference in engine and shifting smoothness.You can change your oil when ever you like. Everyday if you wanted to.
My K8 shifts better for sure since the switch to Amsoil. I used to get an occasional false neutral between 4th and 5th but it hasn't happened even once this season since I went too the Amsoil!![]()
+100 on what BIKE DUDE says---noticed a big difference in my shifting when I switched to amsoil....extended oil change intervals too---
I'm right at 49k on my '06 and I have had NO engine troubles--haven't touched inside![]()
