Who makes wesson oil? I never heard of it.I use wesson oil![]()
Betty Crocker I thinkWho makes wesson oil? I never heard of it.I use wesson oil![]()
Exactly so. It's painful to read some of these threads with the amount of mis-information put forth.way too much folklore running around.
ahh I did't see that part at the bottom when I copied it, yes I know you should only use premium fuel with the newer models.+187 octane? I will never put 87 octane in my busa or I might damage the engine, I hope you dident.Heres some info I found:
600 miles 5000 rpms - change oil at 600. use regular oil (not synthetic). Get a couple of good throtle twists in 1st gear up tp 5000 to seat everything.
601 - 1000 8500 RPMs After 1000, redline.
Change oil at about 1600. Use Regular oil (not Synthetic)
Change Oil at about 3000 - Use synthetic blend (Motul 10 - 40 or Castrol ACTEVO 10 - 40)
Stay with 10 - 40.
Also use 87 octane. 93 will cause you to pick up a lag.
Where did you get this info?
K8 owners manual clearly says to use super of 91 octane or higher always!
Gen I may be different but 87 is not to be used in the Gen II!
I was under the impression that the engine changes made on the 08 Busa would require a slower burning gas therefore making a 91 octane mandatory. Burning high octane in prior years is not a good thing as the stroke is such that a quick burning fuel would cause a loss of power and be counter productive to the engine stroke. Have I got this wrong? My 04 manual specifically calls for 87 octane.+187 octane? I will never put 87 octane in my busa or I might damage the engine, I hope you dident.Heres some info I found:
Stay with 10 - 40.
Page 2-2 states that ;My 04 manual specifically calls for 87 octane.
Your '04 Hayabusa engine does not have the higher compression ratio of 12.5:1 that the Gen II bikes have.My 04 manual specifically calls for 87 octane.
Man is that expensive. Is Mobil 1 Racing 4T 10W-40 worth it?Mobil 1 Racing 4T 10W-40 (Shipping Included)
Item# MR4T/6
$63.60 for 6 quarts
Recommended for four-cycle motorcycles that specify a 10W-40 oil.
Engineered for on-road, off-road and competition four-cycle motorcycles.
Helps provide optimum acceleration and peak horsepower.
Scientifically developed high-performance additive system.
Provides excellent engine protection at peak rpm.
Protects against slippage in wet-clutch engine/transmission systems.
Exceeds requirements of API Service Categories SH, SG/CF, CD, JASO MA.
What does Mobil 1 MX4T offer that Mobil 1 for cars does not?
Regular Price: $9.95 per quart
sold in 1 case of 6 U.S. Quarts; No extra cost for shipping
Oh, really...i wouldn't go without changing the oil for that long; especially when putting the bike under high stress conditions -- racing at the dragstrip or running hard on the street.Well at $10 a quart that is the cheapest I have found. Good for 10k miles or 1 year of use. That is money savings in the long run.
I totally agree!! I've been running full Synthetic in all my bikes for years and I've never had an engine problem. I always switch over on the first 600 mile service. And FWIW Advance Auto is now selling Mobile One full synthetic motorcycle oil. I didn't know that untill a few weeks ago.SLA1500.......Your friend may be a total gear head, but not a well informed one. "roller bearings sliding" GEEEEZ, what nonsense. He needs to get out of his garage and do some learnin'. That is some pin-headed Harley folklore, besides you aren't riding a two wheeled tractor...............
Ron
Suzuki has had full synthetic oil for several years now. I started using it when I bought my 06 1K and now in the 08 Busa. It's good oil.Not trying to enter a debate here or anything, but I just found out that Suzuki makes a full synthetic. Apparently they started this year. I picked some up and will be making the switch tonight. My main reasoning is to avoid pulling the fairing off as much as possibleGuys at the dealership said it will be fine for 6k miles or more. Secondarily, I'm hoping that the clutch engagement will be a little more smooth.![]()
Hmm cool, I usually assume the guy at the parts department knows what he's talking about. He's a really knowledgeable dude but guess he was mistaken. Anyways, good to know someone is using it!Suzuki has had full synthetic oil for several years now. I started using it when I bought my 06 1K and now in the 08 Busa. It's good oil.Not trying to enter a debate here or anything, but I just found out that Suzuki makes a full synthetic. Apparently they started this year. I picked some up and will be making the switch tonight. My main reasoning is to avoid pulling the fairing off as much as possibleGuys at the dealership said it will be fine for 6k miles or more. Secondarily, I'm hoping that the clutch engagement will be a little more smooth.![]()
I stick with a olive oil its runs great with fewer calories.Betty Crocker I thinkWho makes wesson oil? I never heard of it.I use wesson oil
its just cooking oil I was just kidding![]()
