First off, i spent 3 hours on here last night researching stator, rectifier, starter, and battery. And im not finding anything that matches my issue, or any facts on how to test some of these systems. So i need your help.
When i bought my hayabusa last week the guy told me it needed a starter.
I was ok with that. For the money i paid for it, I had extra to buy one if need be.
When its cold, the starter spins its ass off and the headlights shine strong while its spinning, and fires right up. Ride it for 20 minutes cut it off and try again. It turns slow and stops after 3-4 rotations headlights dimming almost dark. You can feel the exhaust valves open from the Poof at the exhaust so it is turning over.
First thing i did was test the battery. It was borderline so i bought another.
Charged it 8 hours. Fired up fine 4 times in a row while it was cold, rode it 20 minutes, and then the same issue. It turns over slow 2-5 rotations and stops, Headlights dim.
I do my research and some say weak starter, some say bad ground, some say faulty rectifier.
But here is the thing.... If i hit the starter button and it turns over slow, i release it, wait for fuel pump to stop running and hit it again sometimes, very randomly it will spin fast like everything is ok and the bike starts. Cut it off ,hit the starter and its dead again. Hit it again and it spinds strong.
The colder the bike is the more consistent it starts the headlights shining strong while cranking. The hotter it is the worse the problem gets, with headlights dimming and each time try it sounds like the fuel pump gets weaker. That one time you hit it just right the fuel pump sounds strong the starter is strong and the headlights are bright. WTF!
