OKay, here is the run down of my evening. I wanted to eliminate as much things as I could so i started with the sensors; intake temp, engine temp, coolant temp (i know it only turns on the fan), intake pressure, and atmospheric pressure sensor. I basically checked continuity of all of them, which they are, normally closed and I tried starting the bike with them disconnected and with a jumper (while the bike was hot obviously). No change, no improvement.
I disconnected my power commander. no change, no improvement.
Have any of you had a motorcycle overheat before? My old CBR900RR (carburated) overheated a couple times and as soon as it gets that hot, it does not want to start. Is that because the ECU is preventing the bike from starting so to prevent further damage?!@!? If that is the case, maybe this sensor is being falsely triggered at too low a temperature. What do you guys think!??!?! I checked the spark plugs as well and the bike is still getting a spark...obviously, because i can still push start it. huuummmmmm
In further troubleshooting, i thought maybe my timing was off because i understand that this bike can have a bad cam tensioners and have the chain slip. I basically took off my cam cover and checked the timing points. Both cams had the markers pointed up (#2, and #3), cylinder No.1 was at TDC and the starter clutch markers were aligned. So no problem there.
At this point, the bike is still in pieces but no solution so far. I will have my injectors cleaned, maybe at the site I posted earlier.
Last thing, I noticed that my valves were cruddy as hell. Full of black gunk on the backside of them. Any idea on how to clean them???? I doubt regular fuel injector cleaner works because i used a whole bottle of that sea foam stuff. Let me know.
On to the next possible cause.
