First sorry its taken so long to answer your questions . From what I have researched ( credit XS1100 yamaha forum ) adding or taking away weight never removes vibration it just moves where it is felt in the rev range . A few examples my ZRX drag bike was very smooth with engine crank shaft balancer , but was terrible once removed . The ZX14 uses TWO crank shaft balancers were they Hayabusa uses 1 . The ZX is butter smooth where the Bird starts to give a mild vibration at 4700 rpms on up . ( still smother than most bikes ) Adding heavy bar ends or filling bars with silicone just move it a few hundred RPMS . I tried the heavy bar ends , and there was no noticeable change over the Rizoma end caps . Keep in mind I just did Three Iron butt runs in 8 days , and vibration was never a issue even cruising 100 plus mph at 5500 to 6200 RPMS . My next trick is to try adjusting the crank shaft balancer while my body work is off . Step one MARK shaft , and ARM before making any adjustment to return to original if a improvement is not found in the adjustment range . The factory adjust it pretty close , but they don't ride it afterwards , and the gear teeth wear in so a minor adjustment can help in vibration . It is adjusted by sound while engine is running . I'll make a video soon on the process .
Things to remember Jeff my bird has handle bars that are hollow , and a diffrent top clamp that is over 4 pounds lighter than a stock bird with its solid clip on bars .
Also if you like research Harmonics and vibration you will find some fun stuff . a Simple worn bearing can cause some peaks in vibration
