vacum system ?!
korke
Hy.
How much of the vacum system i can throw away ?
The valve inside the airbox. I can take off and put to the vacum tube a dead end . But is other things needful ?
Can i live only one tube what will go from one throtel in to vacum sensor and other things throw away ?
The bike will be run on race ecu.
I would wan't to replace in the throtel buddys the vacum holes with the nos Y.
In every throtle two Y ..right in to the vacum holes.
I hope my question and idea was understandful as i don't speaks much in english. :beerchug:
Technically you need it all...
The PAIR valve at the front of the motor under the header is the only really "expendable" one you have.. If you remove this line, you must plug off the rest of the AIR system from the airbox.. LEAVE the rest alone..
