Kevin Jones
For the cost of a crank for a 1507, might as well go the boosted route. Just my opinion.
Hi. I agree, but for a street racer all NA does not look fast. And hide the NOS.That's billet, not a weld up
Hi. Has anyone sent head or called for info to make a better busa head Dart,AFR,Brodix or RHS. If there is any interest could find out how many heads that would need to be sold to make a profit. I had a small block chevy 400 .060 over with a 327 stroke crank. I think it was a 353 ci or 358ci. with Brodix heads and manafold with a holly 600 CFM moded 2 barrel carb with NOS [hidden] After the races I would open the hood [ see a 350 with a 2 barrel ]It had pistons and a roller cam.Those big of cams likely won’t gain much hp with stock compression. They likely will push up peak hp/tq a few hundred rpm, but not to 13k. Yes you could spin it that high but power will likely be falling off the edge of a cliff like a rock.
The gen 2 flows better then a gen 1, but still not by much. Only reasons turbo motors make power to 12.5k rpm is because the air is being forced in so that overcomes limitations of head flow. That’s why compression is key with big cams the pistons pull more vacuum on the intake valves before they open. And only then your next hurdle is intake runner flow.
With all that said the stoke of a busa engine is +10mm more then the new liter bikes. That really dictates how much rpm you can turn before stuff starts breaking. Gen 2 cranks by nature are horribly unbalanced. IF and I say IF it were to make power to 13k+ I’m almost certain you’ll see excessive bearing wear if you don’t fold a rod up first.
There, I fixed it for you....I get distracted sometimes motorcycles........blah blah other less important stuff.....motorcycles..helping blind runners.....blah blah other less important stuff...
Keep us posted...View attachment 1620235
Im headed to some 1/8 mile unprep, flashlight man, old worn out track called "street racing haven" in leakseville al in the morn, bout an hr drive to play wit a BUNCH of newer 1k's, me and my buddy on is 14r meeting a couple with 07/08 gsxr 1k's to make a few guys feel silly going back home lololol
Im at abt 67inches, 15/45, shinko hook up leaving at abt 6k pretty much dumping the clutch, end track at abt top of 4th, 280 fully dressed....hope we do well
I been beating up the street with my 60" 1441. Man its a struggle, I can do a mediocre 60 but as soon as I get into second up about 9k at I dunno 100' out, its spin city tachd, into 3rd tachd instantly, 4th n that's only an 1/8th at 17/40. I think I gotta go 18/40 an shorten it up some or go with a smaller motor. Play with the shock, tire pressure, streets is a whole nother game. Not even any pimp juice or anything. 100' out is my issue. Edit:165 suitedView attachment 1620235
my buddy on his 14r was having the same problem until we went m2 revalved shock and the new dunlop dragmax tire, i dial it in for him best i could and no wheelie or spinning problems anymoreI been beating up the street with my 60" 1441. Man its a struggle, I can do a mediocre 60 but as soon as I get into second up about 9k at I dunno 100' out, its spin city tachd, into 3rd tachd instantly, 4th n that's only an 1/8th at 17/40. I think I gotta go 18/40 an shorten it up some or go with a smaller motor. Play with the shock, tire pressure, streets is a whole nother game. Not even any pimp juice or anything. 100' out is my issue. Edit:165 suited
