Tetge, it seems to me you need to quit spending so much time being a mathamtical(sp)geniuos and spend some more time @ the track. It's all about seat time!!!! I haven't been on here much due to my computer sh!t the bed and I haven't had it fixed yet. If you have any questions feel free to ask, I'm far from an expert but do alright at the track.
I just changed my gearing from 17/42 to 16/42. It seems to be helping get outta the gate better and improved my times. With the 17/42 I throughin 4 gears and with 16/42 I go through in 5. Hope this helps.
Jim
My Busa has been to the track on 37 occasions since 07/08/05, shortly after I bought it new. It has made 258 pulls down the 1/4. It has 2700 street miles on it so far. Its main problem seems to be lack of top end pull. Over and over again I get to the 1/8th first versus other bikes like GSXR-1000's and ZX-10R's and Brakelate's ZX-12R and then they steam by me in the second 1/8th. They do 133+ to 140+ and I go 129-131. I hit the 1/8th at 103-104 and they are doing 107-110. I had the bike dyno'ed and it made 143 actual RWHP at 2710' on a 88 degree day. The dyno's software corrected the HP to 160 SAE, which is in line with the SAE numbers of Busa's tested by the magazines.
My riding weight all up with leathers is about 800 pounds. The Busa weighs right at 550 lbs on the drag strip scale. The GSXR-1000 and the ZX-12R both weighed in at less than 400 pounds with fuel and the ZX-12R weighed in at 525 pounds. All the riders are lighter than me too.
So, I guess the combo of high altitude and bad DA; heavy all up curb weight and, untalented rider, have done me in. I am almost curious enough to go on a diet. And, if it were not so much work to get the center stand off the bike, I might even take the center stand off and put the rear under fairing back on. But, the center stand is a real SOB to install. Those springs are almost impossible to stretch into position. And you have to drop the exhaust to get to the bolts.
At least I can still rant.
BTW: A couple of weekends ago I took my daily driver, a 2003 Ford Mustang Cobra to Famoso drag strip up by Bakersfield and ran 11.508 @ 120.22 off a 1.619 60' time on 17" DOT radials. Then I drove it back home. Full interior and all. I have run better 60' times but that was a new personal best with the car. It only manages 11.9's at LACR at 115-116, to give an example of how tough it is to go fast at LACR. So, I have been racing a long time and I am no newbie.
<!--EDIT|Tetge
Reason for Edit: None given...|1133072368 -->
