RedBull
Please.By the look of that......it looks like you are lucky you didn't suffer engine knock.......lubricate, lubricate, lubricate
He said the motor had a high pitched sqeal, not a knock.Please.
That motor was knocking like it was Da Po-lice.
No sir. That was a different thread. This guy said it wouldn't start when it was hot....He said the motor had a high pitched sqeal, not a knock.
Oh, damned Alzheimer's lolNo sir. That was a different thread. This guy said it wouldn't start when it was hot....
Lolol. I suffer from CRS myself.Oh, damned Alzheimer's lol
Hello everyone,
My 2012 hayabusa wont start when its hot. It looks like the battery is dead but once the bike is cool down it starts in very quickly.
I have changed below items.
1. Yuasa battery
2. Clutch plates
3. Self motor
4. Starter coil
5. Oil cooler
6. Radiator
However, the problem still the same. Please advise if i need to check something else to resolve this problem.
See all the pictures of the internals on his motor on the previous page.............Try using a lithium battery. I have a few busa's that have the same issue and a lithium battery got it fixed.
Ain't no battery fixing that.See all the pictures of the internals on his motor on the previous page.............
I recently figured mine out and fixed it. I would have the same symptoms when it was hot but it wouldn’t start turn off slowly like the battery was very weak. It was down in the starter clutch area between the starter and the starter clutch. Once you pull the cover off, the idler gear is the first one the starter touches and the way it is held on is by Holow steel Pin that goes into a recessed hole in the starter housing cover. It needs to fit in the hole and not wobble around at all. Mine was very sloppy which made the gears bind when it tried to turn. I recently put a video on YouTube showing and explaining what I did. If you want to see it, type in Rick Gidney In the search bar of YouTube, I’m just trying to help everybody else out because it was a rough one. Glad to do itHello everyone,
1. Yuasa battery
2. Clutch plates
3. Self motor
4. Starter coil
5. Oil cooler
6. Radiator
