thanks schroef, wow thats it, so much for experimentingyou might get 4-you have to get your 3 licenses first-hint-to do 155 your speedo should read about 170 or so
awesome man thanks thats exactly what i was looking forvcyclenut,
April is the big car meet of the year which tends to slow things up a bit. If you show up ready to be in line all day with the appropriate support crew willing to bring you drinks & nourishment in line you will get the most runs possible. Be there & ready to run first thing in the mornings. Often times things will thin out for the last two hours on Sunday and you may be able to get an extra run or two in then. Showing up Friday for orientation & tech will help things along as well. Check a gearing chart before you head to the track to double check your rpm's at your licensing breaks. The Speedo idea is good but the tach will serve you well. If you blow through a licesnse pass by too much they'll make you run it again! The longest I've ever waited for a run is 3 hours and that was at the April meet last year. That was our 2nd largest event of the year but less effiecent then the larger meet at the end of the year. Many people were able to get 6 runs in at the first meet last year so if you run & get right back in line you can problably do the same.
Good luck & see you out there!
Deb
Dodge that cone, I hear it's badazz, throwing riders and scratching bikes, and shid like that
from reading their site if i get there early friday i can tech and go to rookie orientation friday at 5pmlast years average is 2 runs per day average between runs was Sat 2hrs 58min and Sun 1hr 21min. The first event has a ton of cars since it's the Hot Rod event. Lines are long and every so often one might break down. If you're very quick and go right back in line after each run you'll be able to complete the licensing runs Sunday. Rookie orientation also kills your chance at an early Saturday run.
The best chance at getting the most runs in is the June event but it's hot hot out there.
