Those wheels are gonna look sick Craig.
I entertained the idea of carbon wheels once for my second Gen II Busa...never kept it long enuff to get them. Now its outa the question. Whats the weight diff?
Rubb.
Rubb.
Believe me pictures don’t do them justice. I need to remove tyres, rotors and sprocket from existing wheels then I’ll compare weights.Those wheels are gonna look sick Craig.I entertained the idea of carbon wheels once for my second Gen II Busa...never kept it long enuff to get them. Now its outa the question. Whats the weight diff?
Rubb.
Easily sourced from Japan for $2500AUD for the full set, downside is the ever moving goal post of completion. I’ve been waiting 8 months now.What other bits are going Carbon Fiber on the bike??
I asked my next older brother (who builds boats) about making Carbon Fiber fairings for my bike but after looking at all the pictures of the fairings, he figured it would be too complex for him right now. I told him there's be a market to sell a few copies but he said the cost would be pretty high.
He does a bit of CF on a few boats but as he is getting ready to retire and he has been downsizing his capabilities.
Too bad, would have been cool to have all CF fairings.
Wow, 8 months...hopefully they are awesome when they get there...Easily sourced from Japan for $2500AUD for the full set, downside is the ever moving goal post of completion. I’ve been waiting 8 months now.
They are very complex to produce, much of the complexity comes from the fixing clips and moulding behind each panel which are designed for plastic fairings (clip together plastic joints etc). Also there is a slight degree of shrinkage that can occur which is why some carbon panels e.g. the inner fairing/dash carbon panels don't always have a good fit. Much of the cost goes into mould production, a side fairing could take a 5-6 piece mould. Carbon whether wet layup or pre-preg still has to be applied by hand with vacuum bagging, release layer etc so its quite labor intense and a high consumable system of production. It can also have a fairly high rate of scrap regarding quality control of the first few items produced. For race use it is the way togo as panels are approx half the weight of production, also you could potentially produce and entire top fairing and both side in one piece, also rear faring, seat etc could be a single unit which would obviously speed up pit time and maintenance. Carbon can be brittle even though it is strong lugs and clips can snap off. It can be repaired again by patching up however once the weave is damaged you lose that cosmetic carbon effect that everyone likes. I often get asked to repair car spoilers etc but usually steer well clear because the only way to fix a damaged carbon weave is to re-skin the entire panel, if not a repair sticks out like a saw thumb. Many cosmetic carbon products are merely skinned in carbon and then backed up with fibreglass using polyester resin, looks great and cost effective but not very strong. Ideally all wet layup carbon should be moulded using epoxy resin which adds to the inherent strength.What other bits are going Carbon Fiber on the bike??
8Months! to be fare maybe production shut down for a while due to Covid.Easily sourced from Japan for $2500AUD for the full set, downside is the ever moving goal post of completion. I’ve been waiting 8 months now.
Awesome response-thank you.They are very complex to produce, much of the complexity comes from the fixing clips and moulding behind each panel which are designed for plastic fairings (clip together plastic joints etc). Also there is a slight degree of shrinkage that can occur which is why some carbon panels e.g. the inner fairing/dash carbon panels don't always have a good fit. Much of the cost goes into mould production, a side fairing could take a 5-6 piece mould. Carbon whether wet layup or pre-preg still has to be applied by hand with vacuum bagging, release layer etc so its quite labor intense and a high consumable system of production. It can also have a fairly high rate of scrap regarding quality control of the first few items produced. For race use it is the way togo as panels are approx half the weight of production, also you could potentially produce and entire top fairing and both side in one piece, also rear faring, seat etc could be a single unit which would obviously speed up pit time and maintenance. Carbon can be brittle even though it is strong lugs and clips can snap off. It can be repaired again by patching up however once the weave is damaged you lose that cosmetic carbon effect that everyone likes. I often get asked to repair car spoilers etc but usually steer well clear because the only way to fix a damaged carbon weave is to re-skin the entire panel, if not a repair sticks out like a saw thumb. Many cosmetic carbon products are merely skinned in carbon and then backed up with fibreglass using polyester resin, looks great and cost effective but not very strong. Ideally all wet layup carbon should be moulded using epoxy resin which adds to the inherent strength.
Pics attached give you an idea of how an item can be repaired/re-skinned.
I have a couple of areas I intend to add carbon to on this build.. don't want to say to much just now as I'm only managing to fit this in around work.
That tank would be hard on us old fat guys....Now if I was to make a 'full' carbon fairing set I don't see much point in replicating the originals, there are several manufactures already doing this.
I would want to produce something entirely different, maybe something like this design by Jakusa. I did correspond with him sometime ago with a view to this. All depends upon potential order numbers as development and production would need quiet an investment.
...and theres not much suspension travel on the front.That tank would be hard on us old fat guys....
Yes that would be one way todo it. I have seen carbon fairings incorporating both sides and nose in one piece (forget who makes them) I'm sure someone else on here will know. Ideally a 'spare' Busa needs to be used as a basis to produce a full kit, probably using model clay and or foam to gain the shapes eventually building up ready to mould stage... weeks of work! Vehicle/motorcycle design being largely subjective would ideally require a prototype to be produced to gain initial customer feedback.The intricate tabs sounds like a hassle Craig. Could it be simplified by using a 1 piece tail and maybe 1 piece side fairing so that the whole bike would only have 2 seams.(side fairings to nose) You could skip the tabs and slots and just have the 2 seams butt up against one another with both sharing an aluminum mounting bracket underneath. Then the kit could include any extra needed hardware to attach your products to stock Busa attachment points. Not an' expert,no fuggin' clue really,but over the years I have attached a lot of different parts from one brand to another.Sometimes removing a strip down the middle of a fender(glassing it back together unseen,underneath) to narrow it for applications on narrower forks. Or chopping,widening,lengthing fuel tanks,etc. Sort of reverse engineer them. Build the pieces to look the way you want...then build the hardware to attach them. Keeping in mind of course what they are going on so that your attachment kit doesn't need 1 meter long (exaggeration) ally brackets and such. I think if you came up with a cool design at a fairly resonable price,the would sell like hotcakes.
Rubb.
I dare say it did/does have an impact and also the supplier won’t ship til they have been test fitted to their demo bike to ensure 100% fitment.8Months! to be fare maybe production shut down for a while due to Covid.
They are saying 1/4 of the weight and instead of being two piece side fairings they become one, tail section becomes one with the hump and indicator pods, same as the front.Wow, 8 months...hopefully they are awesome when they get there...
I wonder how much lighter they are over OEM?
Sounds interesting makes sense producing indicators moulded in, think I’d still want the hump removable. Is it for road use? Would love to see some pics in due courseThey are saying 1/4 of the weight and instead of being two piece side fairings they become one, tail section becomes one with the hump and indicator pods, same as the front.
It's 100% road legal, the entire rear section will come off with 6 dzus fasteners.Sounds interesting makes sense producing indicators moulded in, think I’d still want the hump removable. Is it for road use? Would love to see some pics in due course
Have you any pics yet sounds interesting?It's 100% road legal, the entire rear section will come off with 6 dzus fasteners.
