Skip has his running 9 minutes after unboxing
I’d say this is generous and that I’ll have over double the time of anyone who has done this before. But I’m a slow worker sometimes and am trying to learn about tuning at the same time so when it’s running I’ll have a better idea of what I’m doing.I would be willing to bet you may go double that on your project. But for sure it's time consuming for full on harnesses, and that i would say it labor hours putting it together, with a lot of time before hand planning and mapping things out for what inputs and outputs will be used.
I really like the plug and play option as the labor is significantly less, and so is cost, and I am not reinventing any of the already in place safety stuff for starter/clutch/sidestand/fusebox, hand controls, lighting, etc etc. Provided that the bike's harness is in good shape, which hopefully on Gen3s this will mostly be true LOL.
My hopes are to have a very nice Gen3 system plug and play in the $3-$4k range as a turn key setup including Sport or Race ECU, wiring, ignition ignitor, wideband, functional dash etc.
Hi. Who ever wants a MAXX Race ECU get the Race H2O one and if you want to run VP M1 you need a different igniter box and fuel pump about $2,000.00. As I will be running 3 tunes pump 93 + VP C16 and VP M1 That is why I have over $30,000.00 set aside and I think I will need at least $20,000.00 more. I better start eating less and work more.Skip trying out auto blip on downshifts on his dyno
Htp has one for gen1, but its $$$All these features makes me want DBW. Too bad there isn't a cable pull servo readily available.
