The BoostsBySmith Gen3 2022 Hayabusa Plug&Play MaxxECU Sport will have plenty of available inputs and outputs using my ecu adapter with a number of stock things handled over CAN versus consuming of all the Maxxs available inputs.
All of the stock sensors are being used except map, baro (map sensor is built in on a maxxecu), narrowband o2 (maxxecu has a wideband o2 built in).
5 spare analog inputs with coolant, intake air temp, quick shifter load cell, gear position, and kickstand position handled over CAN in my ecu adapter box. Use these for pressure sensors, laser ride height, air shifter input, tire temp, shock travel, etc.
3 CAN based ground inputs for buttons and switches over CAN, use one of these for an arming switch for autoshift, or to arm nos, etc.
5 spare ground outputs
Gpo1,2,3, as well as ign5 and 6 going through mosfets to provide a useful output for air shifter, boost control, water pumps, shift light, nitrous solenoids, water injection, etc
3 additional lower speed general purpose ground outputs available through my ecu adapter over CAN, reserved for warning lamp or other things that dont require instantaneous precision control.
A few fun things that Maxx will do that you cant over stock: rolling launch control, infinite step adjustability on the fly using stock mode buttons, plus all of the normal fun stuff you can with standalones.
#maxxecu #hayabusa #gen3hayabusa #plugandplay
